Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
A/C electrical issue 02 EM2
Old Jun 1, 2018 | 02:48 PM
thisguyaves's Avatar
Default A/C electrical issue 02 EM2
When the AC works, it works great. It intermitantly decides not to, and it's usually at a time when I can't check it (on my way to work.) But today I had the fortune of a morning off and the AC decided to quit on me in the driveway. It's electrical. How's the AC button tell the compressor relay to turn on?
Some back ground:
I've read through the FAQ A/C post in tech/misc, and I already had a good grasp on the operation of the AC system. I've got good high and low side pressure. Compressor clutch doesn't kick on when I tap it with a hammer, so it's not shim spacing. I dont have leaks. I've worked in car audio for a few years now and have a good understanding of 12v electrical.
So with the engine running and AC on, but no compressor spinning, when I remove the compressor relay and multimeter the relay coil slots (85/86) they have +/-0.1 volts. This tells me SOMETHING in the BCM/climate control array isn't switching the power to the compressor relay. I confirmed this by shorting out the supply/load pins to each other, at which time the compressor engages, fan turns on, and cabin temp drops without fail. So what is between the AC button and the relay that could randomly mess up? Does this particular car have an AC system thermostat that is somehow malfunctioning? The light turns on in the AC button and everything, but the relay doesn't get the message. Factory wire colors and routing location/functions would be helpful. Would I damage anything by bypassing the OEM wiring setup?
Old Jun 3, 2018 | 12:22 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: A/C electrical issue 02 EM2
With the ignition switch turned to the ON (II) position, the heater control panel grounds the A/C ON input of the ECM/PCM through the A/C pressure switch and the multiplex control unit. The ECM/PCM then grounds the A/C compressor clutch relay coil. This energizes the coil, which closes the relay contacts and provides voltage through fuse 1 to the A/C compressor clutch.
If the temperature at the evaporator gets too cold, the evaporator temperature sensor sends a signal to the heater control panel to turn off the A/C compressor clutch.
If the A/C pressure switch sense abnormally high or low pressure, the switch opens the circuit. This removes ground from the ECM/PCM, and turns off the compressor.
Old Jun 3, 2018 | 01:47 PM
So I might have a faulty evaporator temp sensor...
TurboEM1
Acura TSX
Aug 18, 2018 02:56 PM
bruins767
Honda Civic (2006 - 2015)
Sep 16, 2014 04:36 PM
PL_RACER
Jul 24, 2012 07:20 PM
frank316
17
Jun 20, 2011 03:44 PM
hmtcrxsir
22
Jul 25, 2008 03:19 PM
