Strange stalling at different times
Old May 29, 2018 | 03:22 PM
WaywardGalaxy's Avatar
Default Strange stalling at different times
Hey everyone,
I have a strange stalling issue in my 1997 Accord Coupe. 2.2L SOHC. No VTEC. Got 280k. The first time this happened, I was driving on the highway going about 70mph. The car completely turns off. If you listen -- I noticed a "click" when it happens. There are two ways I can get it back on. Firstly, (I do not like doing this, but it works) whilst driving when it turns off, I can simply move the key back into the "start" position, which puts it right back where it should be. Or, I can pull over, put it in Park, and re-start it. It starts back up every time. I'm wondering if this could be an EGR problem, as I do have a code for it. Or, perhaps, ignition cylinder or switch? I've been meaning to clean the EGR and it's respective passages, just haven't had time. The 'fact' that the car can restart upon turning key back to "start" is what makes me think it's the ignition cylinder and/or switch going bad. To be honest, the car stalling has been an issue that's been getting worse and worse. I've owned the car only a short year, and, so far, it's been great. Other than this, of course.
I've replaced the intake manifold gaskets and lower o-rings and the alternator. Next thing I was going to tackle is serpentine belt(thought the belt was good enough so I cheaped out and didn't buy a new one -- now it's chirping with the AC on), and EGR & it's passages.
Thanks for all your help guys,
-WG
Old May 31, 2018 | 11:56 AM
XRACER63's Avatar
Default Re: Strange stalling at different times
check your ignition switch. Honda has had issues with the ignition in your steering column. i had same issue found mine burned out.
Old May 31, 2018 | 11:16 PM
holmesnmanny's Avatar
Its likely going to be either the lock cylinder or the ignition switch. If neither have been replaced I would just replace both to be on the safe side.
89ED
Jan 24, 2017 12:08 AM
Moog_enep3
Nov 6, 2013 11:03 AM
rasta420high
Dec 19, 2010 09:56 AM
TypeRod
Mar 11, 2010 01:24 PM
