Camber/Caster issue
Old May 29, 2018 | 01:59 PM
Natsu09's Avatar
Default Camber/Caster issue
Hiya H/T,
I'm stumped and need some assistance. I have a 91 DX Hatchback, I just put in upper control arms, lower ball joints and outer tie rods, took it to get new tires an alignment. After the adjustments Front right camber -3.6, Front right caster 2.5...
The car is stock other that I put Integra Fat fives on it when I bought it >1 year
When I took the steering knuckle off nothing was damaged or bent, the hub didn't have play in it, the body frame is straight. I called the previous owner and the car hasn't been in an accident or anything of that sort.
How can I fix this? More that anything what would be the cause for those 2 to be out of significantly out of spec?
I know I can buy adjustable upper control arms would solve the camber issue (hopefully), but how can I solve the caster?
Old May 29, 2018 | 02:44 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Camber/Caster issue
Have you changes your radius rod bushings?
... and all the suspension bushings for that matter.
Might also have a bent control arm.
It wouldn't need to have been in a body damaging accident where all it would take is a a good bump into a curb could bend it.
Old May 30, 2018 | 06:32 AM
scelestus's Avatar
Bent control arms are a real option, did that a few years ago sliding into a curb. Fun day, that.
Stupid questions, but were all the parts installed correctly? Was the alignment tech on an acid trip? That's a lot of camber to achieve without adjustable arms.
What were the numbers for the front left?
Old May 30, 2018 | 09:06 AM
Tyson's Avatar
its a 28 year old car man.... metal and rubber has shifted somewhere. but its no big deal. nothing to fix.
Old May 30, 2018 | 09:56 PM
Marcos Barrios's Avatar
to actually answer the question
to fix the issue with the caster you need to look into the radius rods
the rods them selves or the bushings for the rods
Old May 31, 2018 | 10:26 AM
Natsu09's Avatar
Yesterday I put the car on a lift and checked the lower control arms, no damages.
The bushings were all replaced the same time I bought the car with ES (Someone locally had a set, but totaled their car).
I looked at the radius bushings(didn't remove them) they aren't destroyed, just looks old and worn and I will look into replacing them.
The left side specs are camber -0.7, caster 0.3.
The parts were all installed correctly and the tech wasn't on an acid trip lol. I had some one recheck the alignment and still the same.
Driving the car since the alignment, now has a pull to the right (who would've thought!). Have to see if I can fit adjustable uppers in my budget
Thanks for all the help!
ChevelleSSLS6
Mar 10, 2009 01:05 PM
Integritycaptain90
May 22, 2008 06:23 AM
bugster
Jan 30, 2007 04:05 PM
CRXDaddy78155
25
Oct 3, 2006 04:58 AM
Tyson
Dec 1, 2004 03:13 PM
