Malfunction Indicator Lamp is ON
Old May 29, 2018 | 12:09 PM
jillc's Avatar
Default Malfunction Indicator Lamp is ON
I have a 1994 Honda Accord Wagon EX -- this past weekend, the Malfunction Indicator Lamp came on -- I pulled over, turned the car off, then back on again and the light never came on again for the rest of my afternoon of driving.
The following morning, the same thing happened again. I have since found that a person is able to check for sensor codes on their own -- which is cool cause I don't wish to pay over $100 to have a mechanic do it if it's easy enough.
Here's my problem, I'm not sure of the location for point of connection for detecting diagnostic codes.
thank you for reading and for any help anyone may have.
-jillc
Old May 30, 2018 | 04:39 PM
19Accord97's Avatar
Default Re: Malfunction Indicator Lamp is ON
SOLVED: Where is the obd1 connector on a 94 accord? It's - Fixya
You can insert a paper clip into this plug and the number/length of flashes will indicate the code. On OBDII vehicles, the port is behind the ashtray.
Old May 30, 2018 | 04:51 PM
angrysmileyface's Avatar
It's a little light blue 2-wire plug under the glove box. If it's never been moved then it will be in a little plastic holder next to a 3 wire plug (this is for the hds tool I believe) place a paper clip or other small wire in the 2pin connector. Turn key to position II (run, not start). If there are fault codes each of the big 4 systems will flash. (D4, abs, cel, srs) Pattern is the same for any of them. X number of longs followed by y number of shorts. There are several guides on how to interpret the flashes
screammy
Aug 6, 2009 09:41 PM
nguyennhatquang
Nov 16, 2005 02:32 AM
Carson89X
Feb 10, 2005 08:17 AM
danny65
Oct 9, 2002 10:33 PM
honda8882
May 14, 2002 10:30 AM
