FUEL PUMP WORKS WHEN IT WANTS TO!!!
Old May 29, 2018 | 11:08 AM
Bushybob94's Avatar
Default FUEL PUMP WORKS WHEN IT WANTS TO!!!
Hey all I’m new to this forum, I’ve got a 98 civic sedan and my fuel pump doesn’t prime right away and I’m ready to take my car to the derby because of it, I already replaced the main relay, fuel pump, and fuse and still have the same issue, would it be a wiring issue? If so where would I start to run new wires? Thanks in advance
Old May 30, 2018 | 05:06 AM
mk378's Avatar
Default Re: FUEL PUMP WORKS WHEN IT WANTS TO!!!
Check the ECU grounds.
If the CEL stays on when you turn the key on and don't crank, and the fuel pump doesn't run, and you're sure the main relay, grounds, and fuses are good, it could be a bad ECU. One common thing for a bad ECU to do is not turn out the CEL or prime the pump until after the key has been on for several seconds or even minutes. Then the ECU finally boots up and the car can be started.
Old May 30, 2018 | 05:23 AM
tony_2018's Avatar
Fish Twig
check main relay
Old Jun 2, 2018 | 06:08 PM
bloomin's Avatar
BINGO!
I had the same issue. It is failing or out of spec electrolytic capacitors inside the ECU control board, they are replaceable but you must know how to disassemble the circuit board and solder. Usually if you inspect the PCB inside the metal ECU container you will see electrolytic caps that are leaking or bulging or both sometimes the gel material will just dry out and there are no obvious things to see on the cans...they are the weak link in all electronics even today they last at most about 25 years or so.
Old Jun 3, 2018 | 05:22 PM
Freedo_Civegra's Avatar
Originally Posted by bloomin
BINGO!
Electrolytic caps... mini batteries?
Old Jun 3, 2018 | 07:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The original power caps inside an OBD-1 ECU were designed to last 8,000 to 10,000 operational hours. Since most ECU's have reached this operational period, this type of failure will become very common.
Old Jun 5, 2018 | 11:40 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Icon7 Re: FUEL PUMP WORKS WHEN IT WANTS TO!!!
Good to know!
Rawnee7
Jun 21, 2014 08:28 PM
slowpokecivic
Jul 26, 2012 07:37 PM
01 LudeDude
Sep 29, 2011 06:08 PM
madmax94
Feb 28, 2011 02:03 AM
krysted9354
20
Apr 8, 2009 03:32 PM
