Honda CR-V & Element 2WD & 4WD Element & CR-V
RD1 CKF bypass
Old May 25, 2018 | 06:41 PM
Waderick's Avatar
Default RD1 CKF bypass
Hello HT
I pulled the b20z out of my 200k+ mile 99 ex 5spd and traded it for a fresh high comp B20b. I put my original intake etc on the new engine and attempted to perform a CKF bypass but it has never worked.
Since I put in the new engine my CEL blinks 54 for the CKF as well as 61 and 67 for primary O2 and catalyst efficiency
I’ve checked the quicksplices and everything I could think of multiple times. I have checked my Catalytic with a laser thermometer and it seems to be working and I have spare oxygen sensors that have made no difference.
I feel like I’m missing something here... can someone help me out? Does the ckf bypass work on b20z ECU’s?
Thanks
Wade
Old May 28, 2018 | 05:36 PM
Waderick's Avatar
Default Re: RD1 CKF bypass
I’ve found a couple other posts here with people asking similar questions but not getting answers.
https://honda-tech.com/forums/honda-...-swap-3313268/
https://honda-tech.com/forums/honda-...s-crv-3285463/
I know I could swap the oil pump or get a tune but it would be nice to get a solid answer on this.
Old May 28, 2018 | 05:37 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Would have been a lot simpler to just swap the oil pumps.
Old May 28, 2018 | 05:41 PM
Waderick's Avatar
yeah... simpler than a couple quick splices... yeah... so helpful
Old May 28, 2018 | 06:40 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Tell us again how you're having wiring problems?
It'd have been easier to swap the pump while you were changing the timing belt. But you probably didn't do that either, did ya.
Old May 29, 2018 | 03:48 PM
Waderick's Avatar
No I certainly didn’t. I pulled the B20z with the intent to rebuild the block with a new head. I swapped in the B20b for the time being to keep the vehicle moving. I wasn’t keen on slapping the 214k mile oil pump on the much fresher engine. I drive the crv pretty modestly and I anticipated using the b20b for 10k miles or So before I pull it back out. I could throw new parts at the B20b but I’d rather use those resources for said rebuild. Clearly if I was the superior person that you are I would have though, as well as many other things I’m sure.
Old Sep 2, 2018 | 07:05 AM
Waderick's Avatar
It’s been a while but I did fix this issue.
I reveresed the CKF bypass and swapped the oil pump and timing cover. After doing so I still had a CKF code and I was pissed. I couldn’t find any issue with the wiring. After a bit I decided to swap the original distributor from the b20z onto the new engine and my CKF code cleared.
I haven't truly tested the b20b dizzy but I believe it must have been the culprit.
I also ultimately think that the ckf bypass probably does work but don have a true confirmation on that.
Caoboy, I apologize, I was pretty frustrated but you weren’t wrong.
Cletus2k
Jul 7, 2013 02:31 AM
Senior Taco
Oct 9, 2009 10:26 AM
ShamArtist
14
May 26, 2008 07:05 PM
ek-g6
Jan 30, 2008 10:19 PM
RICO_
Honda Civic (2006 - 2015)
Jan 9, 2007 11:51 AM
