1996 radio swap to 2001 6 disc what to do with the security wire? Need help!!!!!!!!!!
Trying to replace the single din & cd player with a 6 disc 39100-S84-A300 from a 2001 Accord. I do not know what to do about the SCTY wire?
Passenger side multiplex control unit is used for a few conveniences, such as allowing the radio and windows to work for a few minutes after the key has been turned to OFF and the doors are still closed.
Have you tried wiring up the system and seeing if it functions correctly without #4 BLU? What are you dong with #19 RED?
Just leave the security input wire disconnected. On 6th generation Accords with the OEM security system, when the audio unit is disconnected the alarm will sound. Essentially, that security input wire loses its ground and the input voltage goes to 10 volts; and the alarm sounds.
redman223
Audio / Security / Video
Jul 10, 2004 07:34 AM
