Wheel and tire sizing help
Old May 24, 2018 | 06:53 PM
Farquea's Avatar
5 Year Member
Default Wheel and tire sizing help
I've been restoring an EF hatch and finally coming round to the wheels and tires. The car is white with black bumpers and so i want to go with white wheels ideally something like Volk TE37s. The hatch has no power steering so i don't want a big thick tire if it's going to make turning even harder. I'm thinking a 15 inch rim but do i want to consider less than a 7inch width, will that be too skinny? I haven't rolled the fenders and don't really want to so what is the max offset i can go with without hitting the fender? Can anyone suggest a good wheel and tire size combo at an offset that will look good without the need for rolling?
Also, i'm in Canada so any suggestions on where to buy would be great, i tried looking up white 15x7 wheels on ebay.com (not.ca) and there really was very little selection to choose from.
Old May 25, 2018 | 10:53 AM
Tyson's Avatar
Default Re: Wheel and tire sizing help
15x6.5 is the standard aftermarket 15" size. oems 15's are 6", but theyre always skinnier.
going to a 15x7 is no big deal. but no need to go any wider, if you could find a wider wheel. you can fit a 205 wide tire. 225 is when youll start to rub.
dont worry about not having power steering, you learn to adapt and drive a bit differently, as long as youre moving slightly forward or backward you can move the steering wheel fine.
Old May 25, 2018 | 11:23 AM
Farquea's Avatar
5 Year Member
Thanks, i might go with 15x6.5 in that case, i had some big wide tires on my corolla and its a much nicer driving experience with the stock thinner wheels. Do you have any info on the maximum offset i can use before i'll rub?
Old May 25, 2018 | 01:15 PM
Tyson's Avatar
i did a search and theres plenty of good information still out there. the lower the offset, the wider it will stick out.
https://honda-tech.com/forums/wheel-...ffset-2498240/
https://honda-tech.com/forums/honda-...wheels-122593/
https://honda-tech.com/forums/honda-...vic-si-107616/
https://www.google.com/search?q=crx+...active&ssui=on
Old May 25, 2018 | 10:03 PM
Farquea's Avatar
5 Year Member
Thanks i'll give those a read! I actually have some Enkei rims on my corolla that are 15" and i think 7.5" wide but i cant tell for certain. I have a 205/50 tire on them currently so i'm not sure if i'm able to confirm the wheel width knowing that?
I might take them off my corolla and give them a go, i'm not sure if they'll be ok though, also not sure what the offset is on those rims.
pxlds
Aug 25, 2014 09:24 PM
tailoredtune
Sep 26, 2011 06:11 PM
Costco
Apr 9, 2011 10:26 PM
ProricanEF
Feb 1, 2011 09:58 AM
FOdoFAsho
Honda Civic (2006 - 2015)
10
Dec 25, 2007 08:39 PM
