Flooded Engine?
Old May 23, 2018 | 02:56 PM
bk0624's Avatar
Default Flooded Engine?
car want to start but it sounds like it backfires and chugs I pulled all the plugs out and 3 are wet 1 is dry same goes when I look down the spark plug wells the 3 that are wet are covered in gas the one that is dry turned straight black and they're brand new please help
Old May 23, 2018 | 03:37 PM
Chance EG's Avatar
Default Re: Flooded Engine?
leave the hood open and the spark plugs out to help the cylinders evaporate, and try again. Use carb cleaner and clean the plugs before putting them back in.
There is likely a deeper problem that caused this in the first place.
Old May 24, 2018 | 02:48 AM
NVturbo's Avatar
O.G. triple O.G.
if 3 out of the 4 plugs are wet, likely, you have a spark/ignition issue. It's either bad spark plug wires or distributor (internal parts)
denierlexiese
Aug 31, 2015 03:08 PM
RichardSiem1
May 22, 2013 01:43 PM
omeezy
Jul 22, 2011 10:57 AM
austinkli
23
Feb 7, 2008 12:57 PM
is3oo
Jun 26, 2002 10:58 AM
