Leak
I have a coolant leak from the bottom of my car. I don't know what is causing it but I am assuming it's from the water pump. I can see that the seal is off and I can see coolant dripping. My car is a 1998 Honda Accord DX.
Verify the source then take it from there. If you have reasonable suspicion that the pump is to blame, rent a pressure tester from your local parts store and pressurize the system. If so, probably not a bad time to change the timing belt as well.
klion22
May 27, 2008 12:28 PM
