Valve Noise???
Old May 18, 2018 | 06:26 PM
RyanB1019's Avatar
Default Valve Noise???
So i just bought a 01 accord with the 2.3 vtec. When I am accelerating and get into higher RPMS I hear what sounds like valve noise to me! Its kinda a high pitched rattle. Kinda hard to describe. I checked and adjusted the valve lash and still have the noise. It is only when i am accelerating. I I am just sit there and rev the engine you dont hear it. Any ideas?
Old May 18, 2018 | 07:40 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Valve Noise???
F-SOHC series engines to tend to get a bit loud in the higher rev range under load. Before replacing the old engine in the 95 EX I gave it a few hard, in anger, runs and the engine does get loud in the upper range.
Old May 18, 2018 | 08:02 PM
holmesnmanny's Avatar
run it to close to empty and fill up with 91 or 92 grade and see if it goes away
Old May 20, 2018 | 05:21 PM
RyanB1019's Avatar
Thanks for the feed back. Ill give the premium gas a try and see if that helps at all.
ednyboo
Jan 6, 2007 10:23 AM
mynameisjonas
Feb 20, 2005 09:39 PM
rickytz7111
Jan 1, 2004 11:00 AM
BryanS
Sep 25, 2001 10:46 AM
