Hello my name is akeem i own a 89 crx si with a high comp z6
Old May 16, 2018 | 03:01 PM
Akeem Willis's Avatar
Default Hello my name is akeem i own a 89 crx si with a high comp z6
Old May 16, 2018 | 05:22 PM
Default Re: Hello my name is akeem i own a 89 crx si with a high comp z6
!!! Need help car start but only run for like ten mins then deads out i i placed fuel pump , fuel filter and i try different dizzy everything
Old May 18, 2018 | 08:26 AM
4drEF's Avatar
Keyboard Humorist
When it deads out, does it starts right back up?
Do you get a Check Engine Light when it deads?
Have you checked for codes?
If it does not starts right back up when it deads, do a check for spark and fuel.
my first guess is that your main relay is starting to fail.
Old May 19, 2018 | 08:29 AM
Thanks bro for the reply and can't really get codes for us resaon dash not working car run fine for three days after the rebuild and drive it to work and in left me there so i Chang the fuel pump and now that wat it do don't know if it's cause i have p29 piston and the compression change but i dont know i try everything from my buddy dizzy too his pressure regulator his ecu but i also was thinking of the defualted fuel pump cause is one of them eBay high flow ones for like 45 bucks
Old Aug 2, 2018 | 12:38 PM
linkdeezie's Avatar
Icon6 Re: Hello my name is akeem i own a 89 crx si with a high comp z6
LOL - I couldn't resist...my fav movie of all time
dylaxiin
May 9, 2011 07:28 PM
caliREDsuns
11
Apr 22, 2011 06:30 AM
iNDyCRX
Apr 24, 2008 12:54 PM
HutchCRXSi
10
Sep 12, 2007 10:42 AM
jdm_eg
21
Sep 7, 2004 06:49 AM
