Lack of power/odd acceleration
Old May 15, 2018 | 09:40 PM
bk0624's Avatar
Icon6 Lack of power/odd acceleration
Ok let me start by saying i have a 96 accord f22b1 about 200k on it blah blah. i have fixed all my oil leaks and today realized i am disappearing coolant somewhere somehow. Ive also had this issue where my car revs super weird if i accelerate while cornering in a turn it will revs to like 4-5k and stick then drop back down (it is an auto) does anyone have experience with this problem or any possible suggestions. also on the note of my coolant leak i dont see any visable leaks so what is a good way to test a head gasket on these motors? thanks for the help sorry im a noob!
Old May 17, 2018 | 02:57 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Lack of power/odd acceleration
Head gasket use a compression tester or a leakdown test. Dye in teh coolant may also show where the coolant may be spraying/misting. Which would leave no puddles/drips but the dye would show up where the spray is.
If your radiator is original, check it carefully. Look at the upper tank under the radiator cap, that large flat area is known to deform, leak and eventually blow. I've had one radiator tank leak, there leaving no real signs of a leak until it finally popped. Check the tubes on an original radiator as they can accumulate junk/dirt and weep but not cause a full on leak.
Old May 23, 2018 | 04:10 AM
protheos's Avatar
My experience is that if the transmission fluid is low, weird things like you describe can happen, have you checked that.
Old May 23, 2018 | 06:45 AM
bk0624's Avatar
yeah I checked it and changed it and it still seems to have some sort of issue :,(
Old May 23, 2018 | 01:20 PM
2171USMC's Avatar
Could be multiple things going on. Tranny could be going?
As to the coolant leak, could be what Mad Mike said and his suggestion is good-could be a blown headgasket. Could also be the water pump. That would be the other major component aside from radiator and head gasket.
Old May 23, 2018 | 03:03 PM
holmesnmanny's Avatar
you can rent a coolant pressurizer to pressurize the system and look for leaks
you can compression test to see if the head is warped
dragonman80917
Mar 9, 2015 11:40 AM
tammy3809
Jul 29, 2014 05:11 PM
dwilson
Nov 19, 2010 08:37 AM
Kgill23
Aug 30, 2010 03:14 AM
wdissident
26
Mar 20, 2009 01:23 PM
