blinking oil light, oil is fine
Old May 15, 2018 | 01:59 PM
DavidRai's Avatar
Default blinking oil light, oil is fine
My oil light comes on sometimes and blinks. 2.2l 1996 accord
If I stop the car and turn it off it doesn't come back on. Oil is fine.
What should I be looking for?
Old May 15, 2018 | 04:51 PM
19Accord97's Avatar
Default Re: blinking oil light, oil is fine
The oil light is for pressure, not oil level. it is common for these vehicles to have a bad oil pressure sensor. They are cheap and is located directly above the oil filter.
I'd start with that. Next is going to be plugged or non-working oil pump.
Old May 17, 2018 | 02:47 PM
MAD_MIKE's Avatar
MM Gruppe B
The sensors can fail. If the sensor is oily/leaking then there will not be a pressure differential and the sensor will not function properly. If the sensor is leaking it's most likely in need of replacement.
MyUsernameName
Jun 15, 2017 02:06 PM
tiannalind
Feb 28, 2007 03:15 PM
RIPPO
Dec 22, 2005 07:25 AM
crexer
Jan 12, 2005 06:12 PM
livelife46290
Jul 14, 2004 05:15 AM
