1993 SI D16Z6 Idle HELP
Old May 12, 2018 | 07:20 PM
Honda_Problems's Avatar
Post 1993 SI D16Z6 Idle HELP
I have a 1993 Honda Civic si hatchback that when I turn it on it will idle at about 2k rpm but once I let it sit for about 5 mins it will start to idle from 1.5k to 2k rpm constantly just bouncing back and forth. I need help I cleaned the iacv with carb cleaner and that didn’t seem to work I’m out of ideas I also did change the timing belt and made sure it was timed correctly idk if that would have anything to do with it idling weird though. Please help Honda fam. I want to drive this car again.
Old May 13, 2018 | 05:36 AM
mk378's Avatar
Default Re: 1993 SI D16Z6 Idle HELP
Unplug the IACV, it should drop to less than normal idle. If it still runs fast with the IACV unplugged, find out where the air is getting in.
If it does go slow with the IACV unplugged, the ECU is probably getting false readings from the ECT sensor and commanding a high idle as if the engine were cold. This can happen if the cooling system is not full.
Old May 13, 2018 | 08:26 AM
I will try that either today if I can before work and if not I will tomorrow for sure and let you know what happens thank you
Old May 15, 2018 | 09:36 PM
bk0624's Avatar
I have the exact same issues on my Y8 really hoping this solves the issue
Old May 15, 2018 | 09:38 PM
Thank you my issue was solved. the problem with mine was that the radiator wasn’t full of coolant so I drained it and added more and boom ran fine now I just need a new battery lol
Hondaman45628
Jul 10, 2013 07:23 PM
94hondacivicvtec
Dec 7, 2008 12:44 AM
speedaccordinly24
May 17, 2003 04:40 PM
Spade
Jul 1, 2002 10:49 AM
