H2b info
Hello everyone.....anybody know what whp i will get with h2b swap with this setup info??
h22a jdm stock block stock head
3" intake with bpi velocity stack
stock intake manifold and throttle body
1320 h2b header 2.5" collector
3" k teller exhaust with straight thro vibrant muffler
itr lsd gearbox with 4.4 fd
Yonaka 6 puck clutch kit
fidannza 7.5 lbs flywheel
balance shaft delete
no steering, no ac, vms lightweight crank pulley
and what time at 1/4 mile strip with this setup in ek chassis with 2400 lbs with driver and skunk 2 drag coilovers with 23" slick and what time with street tires, all that with approximation...
Around 200whp.. you should be able to hit mid 12s..
If you don't have the flywheel yet, i'd invest in something like a Hondata S300.. you will get more out of that with a good tuner. Also you're set up for future upgrades.
The S300 just has more features.
I prefer Neptune RTP, works great and it's a little cheaper than the S300.
Always preload on radial tires. I haven't run slicks before so someone else will have to chime in on that. I preload and launch at the RPM that is best for my engine/suspension/vehicle weight/track prep/track temp/clutch/tire pressure/tire compound, based entirely on how I felt it do on the launch previous. That's what I'm trying to say, your question can't be answered with any degree of accuracy unless by someone with your EXACT same engine/clutch/hp/tq/vehicle weight, EXACT same track, EXACT same day.
Just go to the track and launch it. If you spin and go nowhere, launch at a lower RPM next run, lower pressure, etc. If you bog and go nowhere, launch at a higher RPM. It's that simple.
Thanks agains guys!!! What you think about 205/60/13 m&h racemasters with dot aproved??? I will participate at the streey category and i need some dot slicks...
Snizzoop
Nov 16, 2008 11:48 AM
