Cd5 h22a swap help
Old May 8, 2018 | 07:16 PM
94Cd5h22a's Avatar
Default Cd5 h22a swap help
swapp my 94 Accord ex with a h22a currently using the Accord trans and running a p28 tuned for the moter car runs fine and everything but is not shifting properly
Old May 8, 2018 | 07:18 PM
94Cd5h22a's Avatar
Default Re: Cd5 h22a swap help
And is not throwing any codes beside electric load detector
Old May 9, 2018 | 08:33 AM
MAD_MIKE's Avatar
MM Gruppe B
How is it shifting?
Did you verify the P28 is correct for an AT? Rather than a jumper there should be two resistors RP17 and RP18.
What chip/program are you using?
IIRC ELD sense may not longer function on chipped ECUs, but on the flip side the ELD port can be used for Wideband usage rather than modifying the normal O2 port. I believe you may have to remove a resistor on the ELD circuit and then simply change the function via programming.
Old May 9, 2018 | 11:14 AM
94Cd5h22a's Avatar
Starts off in like 3 and shifts before it should
94Cd5h22a's Avatar
And yes p28 I got is auto ecu
Old May 9, 2018 | 11:15 AM
94Cd5h22a's Avatar
I did not have to use jumper harness my wire harness plug right in to the p28
Old May 9, 2018 | 03:35 PM
MAD_MIKE's Avatar
MM Gruppe B
By jumper I mean a jumper on the board, inside the ECU.
What program/chip/app are you using?
Old May 9, 2018 | 05:05 PM
94Cd5h22a's Avatar
Chrome tune for the h22 is all I know
Old May 9, 2018 | 09:59 PM
Aradin's Avatar
Premium Member
Your 94 has a separate TCU(transmission control unit) in addition to the stock ECU. You will have to use that. Unfortunately the P28 for the civics had the ECU and TCU as one unit, so it's possible you have some weird stuff going on either from having the stock TCU unplugged, or if you still have it plugged in it may be conflicting with(or likely unusable by) the P28. What you need is a P75 ECU from an automatic OBD1 Integra with VTEC/IAB(if needed) provisions added, but left automatic. The P75 can interface with the Accord TCU directly(as those model Integras used a similar ECU/TCU setup as the Accords) and it will function as intended. I got mine from Xenocron back in the day when I need a tuneable setup for my (then) automatic 95. They should be able to help you if you specify exactly what you need. You will then be able to have that setup tuned like any other. You may be restricted to the factory Accord shift points however.
Also, If I recall correctly there a few pins that need to be swapped on the ECU/TCU harnesses for everything to work like stock with the P75.
Old May 10, 2018 | 11:43 AM
94Cd5h22a's Avatar
So I want be able to use the p28 and my tcm is still plugged up
Old May 10, 2018 | 01:43 PM
94Cd5h22a's Avatar
Also the moter is a ond2 moter
Old May 10, 2018 | 06:36 PM
Aradin's Avatar
Premium Member
I already plainly explained to you what you need to do. The P28 is not going to work.
Old May 11, 2018 | 02:38 AM
94Cd5h22a's Avatar
Okay I’m going to get p72 tuned for a h22a and see what goes on
Old May 11, 2018 | 12:07 PM
Aradin's Avatar
Premium Member
Good luck with the P72. Which is totally different from the P75 that I know works.
Old May 16, 2018 | 02:21 PM
94Cd5h22a's Avatar
That’s what I meant this tuner I know said I can use a p28 auto ecu and get it tuned it will work fine
Old May 23, 2018 | 02:39 PM
94Cd5h22a's Avatar
[left]Anyone else have clue or something about what ecu would be best bet or what could be wrong with it
Old May 23, 2018 | 03:06 PM
holmesnmanny's Avatar
then why isn't the tuner doing what he says is possible ?
Old May 24, 2018 | 11:40 AM
94Cd5h22a's Avatar
He still hasn’t come to tune the p28 to my car
Sir001
Apr 19, 2012 08:00 AM
borrego_cd5
Apr 27, 2011 10:00 PM
732xghost
Jul 26, 2007 03:03 PM
MASTERTECH
Apr 16, 2005 02:56 PM
abeaujuin
Jul 27, 2004 09:01 AM
