Starting issues
Old May 7, 2018 | 05:20 PM
Razn4u7's Avatar
Default Starting issues
I have an 89 Crx it’s a dx body with an si motor in it. The problem I’m having is it seems like when. It gets hot like after driving on freeway. I shut it off then it doesn’t want to crank over have taken it to a couple different mechanics and they haven’t been able to tell me crap. Can anyone help or have had same problem thanx
Old May 7, 2018 | 05:32 PM
netfreak's Avatar
Default Re: Starting issues
To confirm do you mean it cranks but won't fire or flat out doesn't crank at all?
Old May 7, 2018 | 05:41 PM
Razn4u7's Avatar
Won't crank at all
Old May 7, 2018 | 05:56 PM
2x0's Avatar
2x0
10 Year Member
Seems to be a common problem on the crx. Curious, is your clutch safety switch bypassed, or do you have any other altered wiring in the starter circuit?
Old May 7, 2018 | 09:36 PM
Razn4u7's Avatar
There was yes but I just replaced starter switch and eliminated all that crap. So we'll see what happens so far it starts. Going for a test drive right now. Will let you know what happens lol
Old May 8, 2018 | 03:20 AM
2x0's Avatar
2x0
10 Year Member
The way I have it now is a wire straight from the ignition switch to the starter solenoid, and I still had the issue when the starter got hot. I believe it was due to it requiring more amps when hot, and using too small a wire.
I changed the wite to 12ga and so far it’s been great even when completely heat soaked
deucedeuceEK
Jul 21, 2015 10:32 AM
seane51
Jan 17, 2014 03:50 PM
RanCRX
16
Feb 2, 2013 01:48 PM
AlfieRoach
Jun 17, 2010 05:47 PM
hotimportcrx
Jun 25, 2005 05:36 PM
