2000 Accord P01701. Log posted
Old May 6, 2018 | 03:14 PM
Hypochondriac's Avatar
Default 2000 Accord P01701. Log posted
Still trying to track down the source of the P01701 CEL. I'm completely baffled. As to what it might be, and would rather not take it to a mechanic. I'm hoping someone here can help me. Here's a google drive link to a log file I made. It's about 2 minutes and includes idle. ~1500 rpm, and ~ 2500 RPM
https://drive.google.com/open?id=1pB...aJyPRbQiKH4Q3E
Engine Load(%) Engine RPM(rpm) Fuel Trim Bank 1 Long Term(%) Fuel Trim Bank 1 Short Term(%) Intake Manifold Pressure(psi) O2 Volts Bank 1 sensor 1(V) O2 Volts Bank 1 sensor 2(V)
Is the order incase you can't see it on the spread sheet
Old May 6, 2018 | 03:59 PM
holmesnmanny's Avatar
Default Re: 2000 Accord P01701. Log posted
as i suggested in your other thread, you need a vacuum pump to do any meaningful testing, and you can manually test the map sensor
Old May 6, 2018 | 04:14 PM
Ok, thanks. You still think it can be a leak? Wouldn't the trims start correcting once the engine is under load? the fuel trim get worse at 1500 and 2500 Rpm I'll have to track down a vacuum pump. Was trying to see if I can rule out other causes first.
Old May 7, 2018 | 10:49 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Thats a horrible representation of the data. Its needs to be in graphical form and with more transient changes, so that the trend can be better analyzed.
Fortunately for you, I am ridiculously good at vehicle diagnostics and interpreting scan data.
Given the limited info,it appears you have a fuel delivery problem.. Since the vehicle is speed density, I'd test the primary O2 sensor, pressure regulator or fuel pump. Others can assist you in the testing procedures.
I suggest taking it to a pro, since this simple fault has you completely baffled......
quenchman
Dec 8, 2011 10:40 AM
jeffk14
Nov 21, 2008 10:52 AM
ruddymart
May 29, 2008 11:44 AM
colnago
Apr 7, 2007 11:14 PM
ProLineDesigns
Jan 17, 2007 04:30 PM
