96 Honda Accord inner tie rod end
Old May 4, 2018 | 09:31 PM
Slick360's Avatar
Default 96 Honda Accord inner tie rod end
I can't seem to remove it. I rented a inner tie rod end remover but it won't grip. The one that looks like a long Black flash light.
Old May 5, 2018 | 02:05 AM
holmesnmanny's Avatar
Default Re: 96 Honda Accord inner tie rod end
you gotta bend the holding washer back so you can get a grip
they put the washer so it doesnt back out
Old May 5, 2018 | 03:24 AM
Slick360's Avatar
I believe i seen one connected away from the tie rod against the steering wheel rod or something like that. Is it that one
Old May 5, 2018 | 03:27 AM
Slick360's Avatar
Also should i use the long Black tool inner tie rod end remover or get a crow foot wrench.
Old May 5, 2018 | 03:42 AM
Slick360's Avatar
Is it the washer in the back
Old May 5, 2018 | 04:57 AM
Slick360's Avatar
As you can see inner tie rod end is dangling, plus i once again rented the long pipe tool and it doesn't fit. I believe it's a17mm size and it doesn't fit
Old May 5, 2018 | 12:55 PM
it should come with three adapters, one will fit, and you gotta bend that washer on both sides away from you to fit the adapter
if you already have the new tie tod, just look at the supplied washer that came with it
Slick360
Suspension & Brakes
May 5, 2018 02:39 PM
MollyXdanger
Jan 8, 2016 08:22 PM
arcticblursx
Mar 29, 2003 01:00 AM
