I am stumped, and looking for ideas, 3 out of 4 windows don't work, only the driver side window works. I have tried using each individual door switch, nothin! I checked the fuses, all the fuses are good. Anything else I can test/check?
1. Make sure the Main Switch on the driver's master switch was not inadvertently turned off. There's been several times where people have inadvertently done this and did not know this was the cause.
2. If it was not due to the main switch turned off. Then swap the power window relay with the radiator fan relay to see if that makes a difference.
3. If still no go, do you have a multi-meter/voltmeter to do some testing?
It's a matter of using a continuity tester and tracing the circuit back from the window motor until you find the source of the problem.
Well, there are various component and wiring as part of the window circuit in question affecting the 3 windows. A continuity tester by itself cannot always get the results or do it easily to narrow down the source of the problem.
