Integra swap
Old May 4, 2018 | 06:04 AM
Jeremy Hoffmann's Avatar
Default Integra swap
I have a 98 integra was wondering if I can swap a b18a1 from a 91 integra in to it and what I would need to make the swap if possible
Old May 4, 2018 | 08:34 AM
.Grimace's Avatar
footwork mastery
Default Re: Integra swap
Hmmm that's a pretty radical idea, in the 20+ years the DA and DC has been around no one has ever thought to try this. Just in case though I'd probably search it.
Yes it is super easy, you'll need to use the 98 sensors in some spots, distributor and alternator but if you search you'll find all your answers.
Old May 4, 2018 | 11:38 AM
NVturbo's Avatar
O.G. triple O.G.
Don't bother.
Old May 4, 2018 | 04:14 PM
HondaPartsHero's Avatar
Technical Hero
Yes but you’ll have to swap all the parts over like: alternator, injectors, distributor, exhaust manifold, and wire the fan switch from your thermostat location to the back of the block.
Old Jun 3, 2018 | 01:27 PM
What distributor do I need obd2 or obd0 and will I need a jumper harness ?
Old Jun 4, 2018 | 05:56 AM
CandyRedRC46's Avatar
Lol why on earth would you put an obd0 distributor in a 98?
Old Jun 4, 2018 | 06:41 PM
the distributor on the motor is obd0 so I was wondering if I could use it with a jumper harness or if I had to get an obd2 and wasn’t sure if I would fit this motor isn’t staying in the car I’m just using it so I have a working car until I get another motor and build it but for the time being I need a working car so I’m using the motor I have just to get me places
tabrubaker323
Jan 26, 2014 04:39 PM
Vtec Civic 93
10
Aug 13, 2010 12:12 AM
hondakevin21
Apr 20, 2006 07:33 PM
menappi
Mar 21, 2005 07:03 PM
