D4 Light flashes
Old May 1, 2018 | 07:40 PM
PapiCD5's Avatar
Default D4 Light flashes
When driving for a period of time my D4 light starts flashing. After a period of time when the car is off (more than an hour) the light is not on until driving an amount of time as I said before. my speedo and rpms act normal when its flashing and my car drives normal. I installed this transmission over the weekend, its a H23 and I also have the H23 tcu too. Thanks
Old May 1, 2018 | 08:13 PM
holmesnmanny's Avatar
Default Re: D4 Light flashes
pull the codes before turning off the car
Old May 1, 2018 | 08:15 PM
PapiCD5's Avatar
Am I able to pull codes if its not flashing? Or do I have to wait for it to start flashing to do it? Because its been on and off all day
Old May 2, 2018 | 05:17 AM
MAD_MIKE's Avatar
MM Gruppe B
Light will flash when there is a current issue.
Light will turn off and store code.
Unless it is a hard fault the light will turn off.
I wouldn't bother with the H23 TCU if you are still running the F22 ECU and engine. Transmission is a 'dumb' device and will operate fine with the F22 TCU.
Old May 2, 2018 | 05:20 AM
PapiCD5's Avatar
Yeah thats what I have in now the h23 tcu
Old May 2, 2018 | 05:29 AM
MAD_MIKE's Avatar
MM Gruppe B
Pull the code(s) and see what it is.
TCU is for shifting, this is based on the torque curve of the engine. An H23 will have a broader torque curve than a F22 so the shift points for an F22 will be off, it may shift too early or late for the F22. In daily putt-putt driving you may not notice any difference, but under 'enthusiastic' driving the shift points may feel 'off'.
Unidentified
Jul 23, 2006 12:32 AM
monalisa overdrive
Apr 8, 2005 02:58 PM
acuraLSSE95
Dec 29, 2004 05:51 PM
