Shift Cable Cover Dosent fit
Old Apr 28, 2018 | 06:56 PM
PapiCD5's Avatar
Default Shift Cable Cover Dosent fit
I just got my h23 auto trans in and the shift cable cover dosent fit , its the cover from
the f22, the Trans didn’t come with it, Any suggestions?
Old May 1, 2018 | 03:38 PM
holmesnmanny's Avatar
Default Re: Shift Cable Cover Dosent fit
you can cross reference the part number across vehicles to see if there are other cars that have one that fits
www.hondapartscheap.com
Old May 2, 2018 | 04:43 AM
MAD_MIKE's Avatar
MM Gruppe B
If the trans is an H4A it should fit, it's a tight fit but it should be fine.
The biggest problem I've encountered with the shift cover is it may not fit correctly if the lower steel TC cover is tweaked even a little bit.
Remove the steel cover and check that the AL cover fits the shift transmission housing.
Also prior to installing, verify the bolt holes are clean, use some anti-seize on your bolts and make sure they thread in properly.
asiansteveo
Honda Fit
Feb 25, 2013 09:10 PM
stevekass
Honda Fit
11
May 6, 2007 10:43 AM
JoeS2000
Honda S2000
Jan 30, 2006 04:53 PM
