2000 accord ac indicator light
Old Apr 26, 2018 | 11:33 AM
tmryan's Avatar
Default 2000 accord ac indicator light
The ac indicator dash light is not working. The air recirculation and rear defroster lights work. The ac functions but the indicator light is out'
If there a light bulb or is the light integral to the havoc unit. If bulb--what bulb is needed and how you replace.
Thanks..
Old Apr 26, 2018 | 01:46 PM
MyAcc0rd's Avatar
Default Re: 2000 accord ac indicator light
I've gotta replace a few tiny interior indicator bulbs soon too. Looks like number 1 here, p# 35851-SP1-901 Honda online store : 2000 accord heater control ('98-'00) parts
You'll have to remove the trim surrounding your stereo/ac control to get to it: remove the 2 screws from directly under it, use a small flat tool (not something that could scratch it) to pry out the clock (from the bottom) and disconnect it, remove the other screw behind the clock holding the stereo trim to the dash, then you can remove the whole trim panel itself, disconnect the ac/heat control connectors, and now you can access and remove the bulb from behind the ac control panel with a small flathead. Might have to tug a little the first time to get it out.
Old Apr 26, 2018 | 02:21 PM
tmryan's Avatar
Thanks for getting back to me.
I looked at the diagram. It looks like the unit has two #1 bulbs. I assume on controls the heat/ac door controls . The other controls the ac/rear defroster, and recirculation button? Both the defroster and recirculation button light up when pushed--only the ac button does not. The actual ac works fine but I cannot tell if the ac is engaged without the light.
Is the bulb I need on the schematic you sent me??
Thanks Tom
Old Apr 26, 2018 | 02:39 PM
MyAcc0rd's Avatar
Since I don't have your specific trim/# of doors etc. I just picked a 2000 accord dx auto, so just change it to your model if that's not it (most likely all the same though). Category electrical>>heater control. It's showing 3 of the number 1 bc it's the same bulb that's used for all of those indicators afaik.
Old Apr 26, 2018 | 03:01 PM
tmryan's Avatar
Thanks. I would assume the ac light bulb is the one in the middle. Will get bulb and try. Thanks for your help. Tom
Randy4000
Apr 8, 2015 08:00 AM
M2B4
Aug 18, 2007 04:41 PM
BoBoChan
Aug 27, 2005 11:31 AM
'00Accordster
Dec 22, 2004 05:45 PM
