How to stop coolant leak after new installed connection Pipe?
Old Apr 24, 2018 | 04:38 AM
parsapour's Avatar
Icon5 How to stop coolant leak after new installed connection Pipe?
I swapped connection Pipe of my Accord 1991 EXI MT5, but after refilling coolant I saw leaking from Thermostat End of the installed pipe, I wonder to know why and how to stop its leaking& if there would be any difference between Japanese Origin as mine is, with the American Manufacturer in forming of the Pipe shape ? I guess the end connecting to T/S may not have proper position or direction to be in line with the T/S can it be a reason for such cause?
meanwhile I applied grease ( general purpose ) on both pipe ends to ease shoving into W/P & T/S . is applied grease safe for O-Rings? or should I use Dielectric Grease on the O-Rings instead ?
Question is how to fix the leak ? can I wrap the O-Ring with pipe sealing tape ?
any comment ?
Thanks.
Old Apr 24, 2018 | 07:06 PM
holmesnmanny's Avatar
Default Re: How to stop coolant leak after new installed connection Pipe?
is it safe to assume you're using a new oring or the same one ? the water pipes should be the same, if you're using a new oring you might just need another pipe or you can try loosening up the bolt that holds the pipe onto the block and try adjusting it
Old Apr 25, 2018 | 04:29 AM
parsapour's Avatar
Thanks, yes I used the new pipe and its O-Rings , also I 've loosen the the holding bolt at the Block , even I rechecked the process by dismantling the T/S assy last evening and wrapped around the end of Pipe beneath of the T/S O-Ring with water pipe sealing tape to support the OI-Ring & prevent it from being flatten under shoving process, result seemed OK , and trace of leak from around Pipe connection to the T/S Housing at next morning check was almost dry, how ever still there been significant leakage spot seen under the car I checked all connecting hoses above the drip area but could not figure where from the leak is formed. will check again this afternoon. Thanks for your hint & comment.
Good luck
Old Apr 26, 2018 | 01:09 AM
I'm sorry, but I can not tell if you are using a new water pipe oring, pictured in part 19 in this illustration.
https://www.hondapartscheap.com/auto...ater-pump-scat
the thermostat has its own gasket in addition to part 19
Old Apr 28, 2018 | 08:57 PM
parsapour's Avatar
Thanks holmesnmanny, thanks for your dedicated time & hints, in fact the new connecting pipe has its own O-Rings with, thus I used them and seems all in order,
SlowDA9teg
Jul 20, 2015 10:42 PM
scottblade
Dec 2, 2005 07:09 PM
superburner2
Jul 25, 2005 07:44 PM
kraig
Jun 6, 2004 12:32 PM
