check engine code 20
code 20 is electronic load detector. honestly, my ECU has thrown this code since the day i converted to MPFI and the car runs fine. IMO if you get code 20 but the car still runs and everything works, just ignore it. its also a possibility that the main relay is going out, if that happens, youll know because the car wont run.
car really bogs, almost stops, for about 1/2second when immediately flooring it at around 3000 rpm then takes off like a rocket, i am also getting a throttle agle sensor code, i beleive this is what's causing this sound correct?
wuhungsixxx
Jul 15, 2002 03:45 PM
