started the car the other day had to replace the starter. now its doing it again
Old Apr 22, 2018 | 03:11 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default started the car the other day had to replace the starter. now its doing it again
so i was working on my car the other day and found out i had a bad starter. i replaced the starter with a new one from oreilys and my car would start with the new one (i havent driven it i just replaced the starter only). a week later, now this new one is having the same symptoms. my relay is clicking like its suppose to but i currently dont have it mounted to the chassis of the vehicle, not like it matters. could it be another bad a starter or something else? all the connections are good, starter signal fuse isnt blown and the battery is full charged since its on a trickle charger. any ideas?
Old Apr 22, 2018 | 05:27 PM
tamboo's Avatar
10 Year Member
Default Re: startered the car the other day had to replace the starter. now its doing it agai
if the new starter is made in china it could be bad right out of the box.
if you have the factory original starter it just may need a rebuild kit.
check your make and model but something like this:
https://www.ebay.com/itm/DENSO-START...9Z2CQo&vxp=mtr
if not just get a new denso unit, problem solved (hopefully). cleaning up grounds is a good idea too.
dont just eyeball them lol.
Old Apr 22, 2018 | 06:29 PM
wunfstgsr's Avatar
Loved
Community Favorite
Take it back to be tested and replaced if need be its under warranty.
Old Apr 22, 2018 | 06:40 PM
fonkernuckle's Avatar
just to give you some possiblilties to check when it fails to start. make sure you have power to the small wire on the solenoid from ignition switch-could be a faulty ignition switch- a relay can click but not work properly when under load. voltage drop test the positive cable at the starter and at the battery-drop should not be more than 300 mv and from the battery cable to batttery post-- also you can momentarily connect a wire from the battery positive terminal to solenoid on the starter (where the small wire goes) to check the new starter it should crank to see if its good- ,make sure the car is not in gear and in neutral if automatic cause it can lunge forward otherwise
Old Apr 22, 2018 | 11:03 PM
i assume you mean test the voltage when the vehicle is off at the starter and then again when the vehicle is on the ON position. hope im reading that correctly. as for the main relay, the connections look good to me but again its the original that came with the vehicle.
big.turbo.daddy
Jun 23, 2015 06:34 PM
crxaddikt
Dec 5, 2007 12:31 PM
Touge Tuning
May 3, 2006 11:14 AM
HXvtec
Nov 6, 2004 02:15 PM
Sukebei Oni
Mar 16, 2003 01:21 AM
