Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2006 Pilot steering wheel controls for after market radio
Old Apr 18, 2018 | 12:28 AM
Gatorphan's Avatar
Default 2006 Pilot steering wheel controls for after market radio
I bought an android stereo (atoto a6) and wanted to know if anyone ever figured out which wires I need to tap for the steering wheel controls. Thanks in advance.
Old Apr 20, 2018 | 09:34 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2006 Pilot steering wheel controls for after market radio
Which side of the wiring are you referring to?
Old Apr 20, 2018 | 09:45 AM
Gatorphan's Avatar
I'm not sure I understand what you're asking.
The unit has 2 wires: Key1 and Key2 which I'm supposed to connect to the steering wheel control wires.
I was just wondering if anyone knew exactly which wires I am supposed to tap.
Old Apr 20, 2018 | 09:47 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Your initial post didn't mentioned the aftermarket unit's wire or the car's wiring.
Old Apr 20, 2018 | 10:08 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Are you unsure of which wires to hook up on your aftermarket unit or which wires for car's own steering wheel controls? Or are you unsure of the wiring for both the car's side and your aftermarket unit?
Only the Pilot EX and EX-L trim levels have the steering wheel controls on the steering wheel. LX do not have steering wheel controls for the audio unit. What trim level is your Pilot?
Old Apr 20, 2018 | 11:18 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Honda Pilot EX and EX-L trim levels have the steering wheel audio control.
  • You can hook up the car's wire directly to the aftermarket head unit if the aftermarket unit has the capability to program/map the steering wheel controls for each button switches.
  • If your aftermarket head unit doesn't have programming/mapping capability, then you would use an aftermarket adapter such as the PacAudio SWI-X or Axxess ASWC, which would give you an interface to program/map the steering wheel audio control buttons.
The Honda Pilot EX and EX-L's Grn/Red wire from the factory harness wire is connected to the aftermarket head unit's SWC Key 1 wire. The Honda Pilot's SWC ground wire (Brn) is connected to the aftermarket's ground wire for SWC (this is not the same wire as SWC Key 2).
SWC Key 2 is probably left unconnected, since the Pilot only uses one control wire (i.e., the Grn/Red wire) and a ground (Brn wire). Some cars have two control wires and the source ground.
On the Honda Pilot each button on the steering wheel radio remote triggers a different voltage drop (resistance) for Volume Up, Volume Down, and Seek; it is controlled through the single wire to the audio unit.
Old Apr 23, 2018 | 09:37 AM
Gatorphan's Avatar
Wow. You went above and beyond. Thank you!
I will give this a try as soon as possible and report back.
Old Apr 23, 2018 | 09:39 AM
Gatorphan's Avatar
Also to answer your question, I have the 2006 EX-L model and the ATOTO A6 does have the mapping feature.
Old Dec 4, 2019 | 02:05 PM
Shoeb Surya's Avatar
This is excellent. I finally managed to get my steering wheel controls working. Connected the green and red wire to the key 1 of the double din Android stereo.
Thanks a lot as I have been struggling to find the connection for sometime now!!
jordandevries
Jun 2, 2019 09:18 AM
pyro13
Apr 2, 2009 08:40 AM
FallenAngelHIM
May 7, 2008 07:44 PM
HondaGuy4Life
Oct 15, 2007 09:38 PM
