where can i get bushing cheap?
alright. does anyone know where i can find bushing the lca? and suspension? what brand do you recommand and how much should i expet to pay
Jeff-
Jeff-
your best bet for the money is to get the ES suspension bushing kit. the stock LCA bushings from honda are like $15 each and at (3) per LCA, it adds up quick...
energy suspension is a pain in the *** to install have to lubricate bushing overnight and then pressed out with a hydraulic press no hammer or puller will do
if you don;t want to do that then its time to buy a new lca from honda
So basically to do this, you would need to pull all your suspension parts that have bushings, take it to a machine shop to get pressed out, then install the new ones? that sounds like a bitch. Probably pretty damn hard with limited tools/experience too.
luckily i have a friend who has a press so i did my rear LCAs when i replaced them. i also did the rear shocks at the same time.
sunsetway
Feb 17, 2004 08:36 PM
