My honda eats antifreeze and spits gasoline
Old Apr 14, 2018 | 08:14 AM
Psihapat's Avatar
Default My honda eats antifreeze and spits gasoline
Honda ED4 1991 sedan, antifreeze smells like gasoline also it spits gas from the exhaust system(smokes like hell, white smoke), i have errors 6 coolant sensor and 9 CYP cylinder also there is oil on the tip of the spark plug from first cylinder, i dont have idea what to do, please help.
Old Apr 14, 2018 | 02:37 PM
scelestus's Avatar
Default Re: My honda eats antifreeze and spits gasoline
Gas in your coolant? Probably would be best to drain your coolant system and refill it with antifreeze then.
White smoke from your exhaust is probably coolant. Consider a new head gasket.
Exhaust might smell like gas because the car is dumping fuel due to the CYP code. Fixing the latter is likely to correct the former.
Old Apr 14, 2018 | 03:32 PM
Psihapat's Avatar
andy ideas how to fix the CYP cylinder code, i readed somewhere that it has to do with the distributor ?
Old Apr 15, 2018 | 09:43 AM
Marcos Barrios's Avatar
it is
its a sensor inside the distributor that can not be changed out
so you can only fix it by replaceing the distributor
but before making that jump
its wise to check the timing belt and make sure its in the right place
and timed right
other wise that could be why you have the code for the cyl position
make since?
pepperdk
Honda CR-V & Element
Jun 11, 2015 03:10 PM
Jmb106jr
May 14, 2011 01:02 PM
fire_fighter97
Oct 19, 2010 11:04 PM
Ozne99
May 27, 2008 08:36 PM
BigIslandBoi
Nov 3, 2003 10:08 PM
