Replacing discontinued parts (95 v6 accord)
If I'm in the wrong place, or if anyone has figured out the right key words to figure this out, PLEASE feel free to point me in the right direction....
The above being said, I have a 1995 ex v6 4-dr AT accord. Yes. I know I should get a new car (for anyone who thinks that) but, this one just seems to need some TLC. In particular, it looks like the breather hoses are starting to deteriorate (hose ends have corrosion so, looks like something leaked). However, every site I go to says the parts are discontinued. I figured that one of you all may know of a similar part from another year and/or vehicle that I could use...so I decided I would ask: Anyone know if there is an alternate part for the A and B breather hoses for a 95 accord v6 ex 4-door?
Thought the actual part numbers would be useful, so am adding them: 19525-P0G-A00 and 19526-P0G-A00 for the "A" and "B" breather hoses, respectively.
i'm still looking. If I figure it out, I will post for others, but I got tired of looking, so I'm asking now:]
Found 3 dealers that still have the parts....apparently some still carry the pat. Just needed to search deeper. When I buy the parts, will let you know where I got them...as long as it's allowed.
Thanks in advance!
Thanks in advance!
Last edited by teahtime; Apr 13, 2018 at 10:37 PM. Reason: added part numbers and status update
Yeah, it looks like they just started not carrying those parts. Normally wear items, especially rubber, are stocked practically indefinitely. Yes, please let us know which place you buy from.
Hi All,
i found 2 other dealers that carry the parts. Seaside Honda and checkered flag Honda. Both have online presences. I ordered from checkered Honda since the shipping costs for both were the same and checkered was a tad less expensive. Note that seaside is in California and checkered is in Norfolk, VA. I haven't yet received the parts, but I was quoted two to ten days.
hope this helps. I will either post another reply or edit this post when we get the parts.
You were correct. The order was cancelled. They didn't have the courtesy to let me know. I checked the status of the order and saw it was cancelled so I called them. ONLY THEN did they say say the part wasn't available. They also said that the system they use doesn't check. So, next time I'll have to call :[
