Which front end camber kit to buy
You don't have camber arms for these cars... either you use the camber bolts or you get camber top plates.
I use both but that is because I run a lot of camber on my time attack car.
So I wouldn't need something like this?https://www.google.com/search?q=2007+honda+civic+si+front+camber+kit&clie nt=ms-android-att-aio-us&sa=X&biw=320&bih=578&noj=1&tbs=vw:l,ss:44&tbm=s hop&srpd=7989398583042323706&prds=epd:176368351264 2777169,paur:ClkAsKraX5jcXJXb3FIcEU6LQPk_zFNrYDa-m87VmR1d-KeQElXwiJr1S1jKPZFEKz6fdKYQvR0ds16SeSAvbZY0xcA-GjWr9uRLZXUwihynLlPBC8GMlv7W0hIZAFPVH70En4WJGiwBNO 2OgE86IM6WOiP4kA,cdl:1,cid:181683034241328769&ved= 0ahUKEwipzrbQhLraAhWCk1kKHU9cBQIQgTYI_QM
As Dave said, these cars don't run upper control arms. They have McPherson struts which only have the top locating bolts to fix the strut to the chassis. The lower control arm has the knuckle attached to it. You adjust camber through the angle of the strut to the chassis, hence the slide plates and bolts.
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
