Painting question and opinions on what to do with this old girl!
I inherited a low mileage Civic EF that i'm currently in the process of fixing up. I may be getting ahead of myself here but once I've done all the work on it, I want to get it looking, you know GOOD! I think I might get it detailed and see how much shine can be got out of the current paint but I'm also considering a re-spray. Having zero experience having a car painted before, is it feasible to re-spray only certain areas, a touch up if you will or do you need to do the whole thing to avoid mismatching paint/shine? My hood and back end seem good but the paint on the sides is a bit faded and there is also small patches of black paint on the doors where it looks like someone re-sprayed the black moulding while still attached.
I also have damage on one side. I've ordered a new fender which is probably the worst of it, so if I get that painted it's just the passenger door i'd need to replace but I think that might be tough to find and wondering if a good shine, polish and spray might make it look at least fine until i do find a new door?
With regard to the black moulding, how can I get these black and new rubbery looking? Should i remove them and paint them with a fresh coat of black or can these usually be restored with special plastic cleaners/polish? Any recommendations of paint type and style of black for those mouldings would be appreciated if thats my way to go.
I basically want to have this car turning heads and shining like new once I'm done and ready to put it back on the road but I'm pretty new to this and so don't know the presumably usual do's and don't in achieving that, hoping someone can gives me some pointers!
Re paint all of it and have it cut and buffed to turn heads.
You can probably polish it as is, but won’t look as clean compared to new Paint.
As for the moldings, I would remove them and remove any old paint and prep them very well and paint them with a satin black paint.
I would say have it done by a professional. Painting a car is not easy if you want it to look original. I was gifted a very low mileage eg sedan from my grandfather and I had a reputable body shop repaint and repair a couple of panels due to some rock chips and a careless driver in a parking lot. They blended it to the original paint so well that you would never know it was repainted. It also costed far less than I thought it would. So if I were you I would go get some estimates from body shops and have it done professionally. After the paint is fully cured(about 2-3 months), you can compound and polish the whole car and it will look like new.
Blending is more challenging and takes experience but I've had quarter panels that were in perfect condition and using a good PPG chromobase have painted a door without having to blend and it looks great.
OP depending on the condition of paint it sounds like a fresh coat of paint is what will most likely work best.
