CEL Code 1 Problem
I replaced the old O2 sensor with a new one and the light still comes on. The light only comes on after driving for about 15-20 minutes.
Any ideas on what it could be?
solved, thank you for the help!
The code 1 does seem to imply that the O2 sensor is bad, but it actually saying that the readings from the O2 are not what the ECU is expecting.
If you have vacuum leaks, exhaust leaks, rich or lean fuel mixture, etc etc. they can all lead to unreasonable O2 readings and pop the code.
Wiring is suspect - especially if you have done a wire tuck or an OBD1 conversion.
What are your bets on a bad fuel pressure regulator? I do smell exhaust gases/gas coming in the cabin area from the front of the engine and possibly gasoline, but nothing leaking to the floor. Idle sometimes get rough maybe 10% of the time and my car has nearly 300k+ miles on it. The only time something leaked gasoline was near the fuel tank when I filled up my tank to max. The fuel leaked from some hose near the fuel tank, so I re-adjusted the clamp at the end of the hose
Do you think this is a safe bet to follow: https://manuals.co/workshop/honda/ci...al/5524663/131
That flowchart is an excellent place to start.
Rather than just throwing parts at it and hoping for a fix, actually doing the tests can save you time and headaches.
Have you tried popping the hood and snooping around for a leak to figure out where that gas smell might be coming from?
If there is a hose leaking or an injector o-ring that has failed, it could very possibly be your problem.
Vomit
Nov 20, 2013 08:24 PM
efhatch1991
Jan 26, 2013 07:05 PM
