im new to hondas and need help with mine
Old Apr 9, 2018 | 04:31 PM
Black-EK_EX's Avatar
Icon2 im new to hondas and need help with mine
Size:  345.1 KBName:  3f1075c514730551b89afe13a6e680a35fba59dd-1.jpeg
Size:  527.1 KBhello im George and i recently bought an EK now i need help solving its problems
the car has been vandalized and my intake has come up missing along with other parts in the car now theres is an empty space on the left side of the d16y8 motor and i need help figuring out what goes there thanks
Old Apr 9, 2018 | 04:46 PM
JDMdoode's Avatar
Default Re: im new to hondas and need help with mine
Looks like a section of the intake with the air-box. I can get you one if interested.
Old Apr 9, 2018 | 04:47 PM
JDMdoode's Avatar
Here’s an old picture of my engine bay for reference
Old Apr 9, 2018 | 05:47 PM
i put a battery but it wont start now it wont even crank any suggestions like a sensor that may need to be plugged in for it to start?
i dont know where much of anything is on this engine . im new
Old Apr 10, 2018 | 12:23 PM
rick_rabies's Avatar
I'm not Rick!
your starter cable not hooked up to fuse box??? by the batter.
you pic shows its all disconnected
Old Apr 10, 2018 | 03:33 PM
how does it wire up i need help with it thank you
Old Apr 11, 2018 | 04:45 AM
I'm not Rick!
google your cars make and model starter wire diagram. its in the pic. loose 8g cable needs to go to fuse box right there.
starter isn't getting power
Old Apr 11, 2018 | 08:06 AM
would that stop it from cranking and starting?
Old Apr 11, 2018 | 11:15 AM
I'm not Rick!
yes. if it wont crank it wont start.
if it don't crank..(starter) is dead or not hooked up to power. your pic shows not hooked to power
Old Apr 11, 2018 | 11:20 AM
I'm not Rick!
circled in red is your starter wire...circled in blue is where it goes. fuse box. you need to google 99 civic starter cable...it will show you. hope this helps
Old Apr 11, 2018 | 07:59 PM
the one with the square thing on it right? if so what do these wire ends go
Old Apr 12, 2018 | 04:26 AM
I'm not Rick!
looks like remote start and alarm hooked up.....best to remove all that garbage.
who knows if it works
who knows if its hacked.
I would just remove it entirely whatever isn't oem.
what state are you in?
Old Apr 12, 2018 | 09:22 AM
Icon5 Re: im new to hondas and need help with mine
could that prevent it from cranking and starting, and also are you talking about the wire with the tab thing id that the one I have to plug in?
Old Apr 13, 2018 | 06:07 PM
lowereddelsolll's Avatar
splice the gummy connection in the black wired you circled and redo the connection that wire is for an aftermarket star so if you redo the connection it may crank or start
Old Apr 13, 2018 | 06:11 PM
I've tried that recently didn't work? thanks
Old Apr 13, 2018 | 06:36 PM
Icon7 Re: im new to hondas and need help with mine
oh then you might as well remove that stuff its just going to get in your way it but probably already meddled with your electrical components
Black-EK_EX
Apr 11, 2018 07:26 PM
CRX 2.0V-T
Jun 15, 2006 10:31 AM
thehondabuddy
Jan 28, 2004 09:58 PM
