Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Broken sensor wire
Old Apr 8, 2018 | 01:39 PM
hondaslave1342's Avatar
Default Broken sensor wire
Help..changing my starter on a 2008 civic and ripped a wire off a sensor..too dark to take photo but it mid way up on the block. Under intake manifold..connected to a big size nut and has one red wire
Old Apr 8, 2018 | 01:46 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Broken sensor wire
Knock sensor connector.
Old Apr 8, 2018 | 01:54 PM
How would go about fixing it..i came completely out with a little blue plug with it
Old Apr 8, 2018 | 02:02 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Various options:
  • Order Honda part no. 30531-RCA-A01 knock sensor pigtail connector from dealer, less than $10. Cut and splice the wiring.
  • Salvage yard
  • etc.
Dealer usually can get in the next day.
Old Apr 8, 2018 | 02:30 PM
Originally Posted by tech8
Various options:
  • Salvage yard
  • etc.
thanks..that starter replacement ssssuuuuckkkks
Old Apr 8, 2018 | 02:37 PM
Cant really cut and splice..wire came completely out of sensor..probably heading to junk yard
Old Apr 8, 2018 | 03:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You would cut the new Honda pigtail wiring and splice into the old wire. Honda part no. 30531-RCA-A01 has rodent resistant tape wrapped around it and a connector to plug into the harness for a V6 Accord.
First photo show the pigtail with rodent proof tape already removed. Second photo is connector for V6 cut off (not used). Part is ready to splice into old wiring.
Old Apr 8, 2018 | 04:31 PM
Thank you..the body is a little different but the the front connector the same?
Old Apr 12, 2018 | 01:32 PM
just received it today and not even close..it has a male prong and mine does not..connector way different
Old Apr 12, 2018 | 04:33 PM
wasted $15..this connector plugs into mine..my connector on the knock sensor is fine..i need the one that plugs into sensor
Old Apr 12, 2018 | 04:37 PM
holmesnmanny's Avatar
best bet is to snip one off at the junkyard
Old Apr 12, 2018 | 04:45 PM
not a single junkyard around here has a 2006 and up civic..none.crazy...
Old Apr 13, 2018 | 03:48 AM
place an ad in the marketplace
Old Apr 13, 2018 | 12:35 PM
rick_rabies's Avatar
I'm not Rick!
take the metal plug insert out of the plug it self....resolder/crimp it back to the wire...push it back in the plug
jaap_15
25
May 2, 2011 01:51 PM
beginmyhonda
Jul 29, 2009 02:14 PM
xtremehawn
10
Dec 3, 2007 12:40 PM
