Honda CR-V & Element 2WD & 4WD Element & CR-V
2006 Honda CR-V headlight problem
Old Apr 7, 2018 | 11:39 AM
Sgalena's Avatar
Default 2006 Honda CR-V headlight problem
My driver side low beam and high beam are not working. I have replaced the bulb, checked the fuses, and tested the relay under the hood. All are good but both lights still not working on drivers side. Is there another relay? Not sure where to go from here,
Old Apr 7, 2018 | 12:18 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2006 Honda CR-V headlight problem
Do you have a voltmeter for testing?
With the headlights switched on (low beam and then high beam), test for power (+) on the Red/Yel wires for the driver side bulb connector. Is there power there?
If not, then test for power at under-hood Fuse No. 15 with the headlights switched on.
Old Apr 8, 2018 | 01:50 AM
UK-Kev's Avatar
As Tech8 has advised above, check for power at the 3 pin bulb plug and check that you have a good ground connection on the three pin plug at the same time you are testing for + (positive) power.
Kirk Hoey
Honda Civic (2001 - 2005)
Sep 28, 2019 11:25 AM
pr1madona
Oct 1, 2016 11:52 AM
Manny 77
Mar 18, 2013 11:37 AM
powerwagon340
Dec 24, 2008 01:07 PM
