2011 CRV ac clutch dead - bypass?
2011 CRV 2.4L - All wheel drive. A mechanic told me the a.c. clutch needs to be replaced (which I agree with) but told me there is no way to bypass the compressor (i dont need a.c.). Yet I keep finding bypass kits on places like rock auto. Can you bypass the clutch using something like this:?
https://www.rockauto.com/en/catalog/...s+pulley,10329
Thanks,
Austin
Thanks,
Austin
It would help if we knew the original issue with the AC. If it's just the clutch, the clutch can be replaced. As an example (not exact):
Most techs don't want to bother with just the clutch as it is easier (and more lucrative) for them to just replace a compressor and recharge the system, than it is to do just the clutch. Although, from the tech's point of view and a warranty perspective, he may opt to avoid a potential return visit, if ANOTHER part of the system fails after doing a clutch. But without more info on what failed, it's difficult to determine what your options are.
Just ended up getting the whole new compressor off amazon for 200$ including a new belt and will replace it myself. Makes it worth it. Still not sure if that bypass would work with my car though, as the mechanic said a by-pass was not possible but it doesn't matter now
AZCR-V
Honda CR-V & Element
Apr 23, 2018 07:58 AM
