brake swap on '90 CRX Si
Old Apr 5, 2018 | 03:47 PM
spoolin2bars's Avatar
Default brake swap on '90 CRX Si
I've read the brake swap sticky, (which is awesome btw) but i just want to be sure I read it correctly. I have a '90 CRX Si i'm restoring to run in Global Time Attack, Nasa, etc.. Wanted to go with slightly larger brakes. I have '92 Integra gsr or 1999 Civic Si brakes to choose from. Would one be better than the other? I started to look for the '90 EX knuckle because everybody was saying that using the Integra one would alter the geometry slightly. But after looking over the brake swap post again, I read that "any 88-00 civic, 90-01 integra caliper and bracket would bolt-on. If thats true it would be great. Anybody have personal experience lmk. Thanks
Old Apr 5, 2018 | 03:59 PM
Tyson's Avatar
Default Re: brake swap on '90 CRX Si
this is true for the REAR caliper only.
i dont recommend anything but stock front brakes. changing knuckles to a DA front knuckle is not good for the track, too much camber gain.
you dont need any bigger brakes on the front. the CRX is not a heavy vehicle. theres plenty of heritage of successful CRX racers that have been very hard on brakes and its really not a problem with the right pads.
Old Apr 6, 2018 | 08:40 AM
acmoc's Avatar
I would get the wilwood kit
It will be lighter wheras the oem swap will be heavier.
Old Apr 6, 2018 | 09:23 AM
That's what I was thinking, but the front rotors looks so tiny. lol. I have been running my turbo miata with stock calipers for years. I just run Carbotech pads, stainless lines and Super Blue or now Motul fluid. That's what i'll end up doing on the CRX too. Already have Stainless lines and all new calipers and rotors. I just need to order either Carbotech Pads or might try G-loc. I'll proabably be running around 250whp but i've got the weight down to 2000lbs so it'll probably be fine. Thanks
Old Apr 6, 2018 | 11:47 AM
solorex's Avatar
I run Hawk DTC-60 on stock brakes, with Brembo blanks. Work really well.
Old Apr 6, 2018 | 12:02 PM
acmoc's Avatar
mrboogie33
Mar 31, 2005 08:53 AM
crxhftosi
Jan 30, 2005 10:13 PM
crexer
20
Mar 17, 2003 05:50 PM
Cementups
11
Oct 20, 2002 10:23 PM
Sam
Oct 31, 2001 02:06 PM
