1998 JDM Accord F20B Front Clip into a 91` Accord???
Old Nov 12, 2002 | 12:00 PM
xcelsurfer's Avatar
Default 1998 JDM Accord F20B Front Clip into a 91` Accord???
Would a 98` JDM Accord F20B fit in a 91` Accord? AND, how good is that engine-it has 80K mi. on it. As you can tell I dont know much about the newer engines.
Old Nov 12, 2002 | 01:29 PM
Old Skool's Avatar
Default Re: 1998 JDM Accord F20B Front Clip into a 91` Accord??? (xcelsurfer)
yes, it would fit
I have a 98 f20 in my 95 with room to spare and it is bad ***
there's some bull **** you might have to work through such as an idle air control motor problem...it has 2 rectangle ports and one triangular port on the rear instead of the typical 2 circular ports like cars over here....that took a while to figure out plus you'll need a custom d.s. axle and other small bullshit, but its fun once its all together
Old Nov 12, 2002 | 02:23 PM
2000Accord5sp's Avatar
Default Re: 1998 JDM Accord F20B Front Clip into a 91` Accord??? ( Foomanshu)
If your question is what your title says then I NO. But if you're talking about just swapping the engine, then yes.
Old Nov 12, 2002 | 04:51 PM
Old Skool's Avatar
Default Re: 1998 JDM Accord F20B Front Clip into a 91` Accord??? (2000Accord5sp)
true, front clip and engine are two totaly different things...the front clip could fit with a lot of body mods and a lot of $$ but it sure would be a bad *** conversion
bonbon
Mar 13, 2005 09:53 PM
quick4thgen
Jan 31, 2004 07:08 PM
Kimo
Nov 20, 2002 12:05 PM
xcelsurfer
Nov 12, 2002 03:12 PM
RUBZERK
Sep 28, 2002 08:56 AM
