Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
06 TSX door lock actuator
Old Mar 31, 2018 | 06:54 PM
pwyley's Avatar
Default 06 TSX door lock actuator
I have an 06 TSX. I just replaced the driver door lock actuator. Everything works except the lock won't activate from the key fob. However, It DOES unlock from the fob. the door panel switch will both lock and unlock all doors. pushing the lock mechanism down will lock all does. Pulling it up unlocks only the driver door. What am I missing?
Old Apr 1, 2018 | 10:04 AM
TheShodan's Avatar
Moderator
Default Re: 06 TSX door lock actuator
a new key FOB (to unlock the door) and a change of settings in the steering controls to have all of the doors unlock, when you the the FOB to unlock all. Pulling on the driver' lock manually will only unblock that one door. That is the Acura design.
Old Apr 1, 2018 | 11:17 AM
pwyley's Avatar
Thanks for the response. I appreciate it very much. I will probably end of buying another fob to make sure, however, I do currently have the two original fobs and both get the same response. The doors do not lock by remote.They do unlock correctly. I have it set to unlock the driver door only on the first press. A second press will unlock all other doors. Pushing the door panel switch sets all locks and unlocks all locks. pressing down the manual lock on the driver door will lock all doors. You are right that pulling it up only unlocks the driver door. I mentioned it only to confirm this too was functioning properly.
Other than the fob, do you have any thoughts?
Thanks again
Old Apr 1, 2018 | 11:21 AM
TheShodan's Avatar
Moderator
Thanks again
Check your settings in the system interface found in your dashboard. That's it..
Old Apr 1, 2018 | 12:20 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Try reprogramming the remote transmitters.
TRANSMITTER PROGRAMMING
Storing transmitter codes:The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood andthe tailgate are closed.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch.
3. Within 1 to 4 sec, turn the ignition switch OFF.
4. Within 1 to 4 sec, turn the ignition switch ON (II).
5. Repeat steps 2 to 4 two more times.
6. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch.
7. Confirm you can hear the sound of the door lock actuators within 1 to 4 sec, then push the transmitter lock or unlock button again, or the code will not be stored.
8. Within 10 sec, aim the transmitters (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons.Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
9. Turn the ignition switch OFF, and remove the key.
10. Confirm proper operation with the transmitters.
Old Apr 2, 2018 | 02:32 PM
pwyley's Avatar
Thank you very much! Reprogramming the fobs did the trick.
William1991b
Jun 26, 2011 04:00 PM
rtcpenguin
Honda Civic (2001 - 2005)
10
Aug 3, 2006 07:39 PM
Intercooler
Nov 18, 2004 08:43 PM
es four
May 20, 2002 11:44 AM
Smurf
Jul 23, 2001 04:45 AM
