Another dumb 5 speed question............
Anybody know if you can swap gearsets between Prelude and Accord 5 speeds? I really don't like the big drop from 1st to 2nd on my '91 EX and I have decided to keep the F22 in my '92 when I get to the drivetrain and try to get more out of it. I would like to replace 2nd gear with the 2nd gear out of a Prelude and also swap in the 4.266 ring and pinion. That will give a more even spread between 1st, 2nd and 3rd and the lower gear set will help compensate for the weak low end torque on take off. If I dropped in the 5th gear from an LX that might also help compensate slightly on MPG's for the lower R & P. This is gonna' be a "driver" not a race car and I've noticed some things on my '91 that I would like to change on the '92. Why bother ? Well if I wasn't screwing with this I'd just be doin' it with something else
. I'm always thinking "what if ?"
from what i've read it is impossible to change parts between the h and f trannies. others in the prelude forum were talking about that just the other day, that's where i got my info from.
i switched to a full h23a1 tranny in my accord.
the gear ratios for 1st and 2nd are the same in the prelude as they are in the accord, if that 1-2 drop is what you want to rid yourself you will be disappointed.
3rd and 4th go by quick though.
the gear ratios for 1st and 2nd are the same in the prelude as they are in the accord, if that 1-2 drop is what you want to rid yourself you will be disappointed. 3rd and 4th go by quick though.
[Modified by Hippie, 4:59 PM 11/12/2002]
I looked into this some a while back. I wanted to swap an accord 5th gear into a lude tranny. deeper accelerrating gears but keep a reasonable RPM at 80mph. I talked to one guy who knew 2 shops that tried it. both failed AFAIK. Apparently H and F series trannies have a different pitch on them, causing them to bind. i think the one shop was carboy racing or something like that.
