Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Ac not working
Old Mar 29, 2018 | 01:24 PM
Tneff38's Avatar
Default Ac not working
2003 civic lx has a leak I replaced all o-rings. Stayed in vacuum I put charge on system has about 70psi both sides/ ac clutch not engaging. Tried to jump pressure switch that did nothing: I am not getting any power to the switch itself and no conductivity from switch to relay. What would be the best bet for me to do? I ran dtc trouble shooting and came back with code 11
Old Mar 29, 2018 | 04:41 PM
holmesnmanny's Avatar
Default Re: Ac not working
check for power at the ac clutch connector with the ac on
and the pressure switch should only allow continuity to ground
Old Mar 29, 2018 | 04:53 PM
Tneff38's Avatar
I jumped the compressor on the relay and it kicked on
Old Mar 29, 2018 | 06:02 PM
Tneff38's Avatar
I switched relay still nothing happened. I jumped the relay and the compressor kicked on.
Promisering
Oct 10, 2018 04:40 PM
akb427
Jun 28, 2013 08:51 AM
lcifers
Jul 8, 2012 01:38 PM
sk8er602
May 22, 2007 07:25 PM
AnitRiceSuperStar
May 15, 2004 05:17 AM
