B18C1 misfire cyl 1... I’m lost
Old Mar 28, 2018 | 07:59 PM
SARS's Avatar
Default B18C1 misfire cyl 1... I’m lost
Hello,
I need some serious help. I am losing my mind. I have a completely stock b18c1. About 5 months ago took the head off and replaced my valve stem seals. Integra has been running fantastic, all until last week...
I am having a misfire on cylinder 1, and I don’t know what the hell to do next, because it’s still happening.
When I pull the plugs connecting to my fuel injectors cyl 1 doesn’t change
heres what I’ve done:
- replaced spark plugs
- checked continuity of spark plug wires (all good)
- replaced cap and rotor
- replaced ignition coil
- replaced cyl 1 injector with known good injector (cleaned)
- made sure oil levels are good
** I did a shakedown of my wires and there are no changes... I was told it could be a short but I’m curious if there’s anything else I could try before getting into wiring...
The confusing part is the misfire CEL goes away when I rev to 3K, then comes back on at idle. When I pull map sensor all is good, but I obviously can’t run it like that.
This is my daily and I’m at a total loss.
Old Mar 28, 2018 | 09:13 PM
GIZZ - EXV's Avatar
Loved
Default Re: B18C1 misfire cyl 1... I’m lost
Is the injector pulsing? Getting power? Is it clicking?
Compression good in #1?
Try another Ecu, p28, p06 even, see if that fires #1.
Longshot, all grounds present? #1 being furthest from everything.
Old Mar 28, 2018 | 10:06 PM
SpiderX1016's Avatar
Do a compression check or better, leak down test on it. Just to rule out the mechanical side.
Old Mar 28, 2018 | 10:38 PM
SARS's Avatar
When I cleaned the replacement and the one I had in there already both clicked to 9 volt. When I pull the injector plug on 1 theres no change, but the other 3 do. I don’t think switching the injector with another like 1-4 to see if it follows will help if I replace it with a known good one.
I haven’t done a compression or leakdown test yet, but I think I need to.
I will try another ECU. See it that does anything. As far as grounds I’ll definitly check, I haven’t done that yet.
Thanks for your response btw!
SARS's Avatar
will do. Thank you!
Old Mar 29, 2018 | 04:08 PM
Krazy613's Avatar
Originally Posted by SARS
Hello,
i had had a similar problem couple years ago but it was the igniter. I just bought a new distributor so not exact but I’ve also had a bad ecu before too do some crazy stuff. An extra ecu lying around is always good.
mindslayer84
Nov 5, 2010 12:59 PM
EvilPinkEye
Sep 1, 2006 10:20 AM
mtm584
19
Aug 6, 2004 08:33 AM
jmb92
Feb 23, 2004 05:39 PM
SSBlueDC2
Feb 7, 2003 07:45 PM
