Need a little guidance for NA build.
Old Mar 28, 2018 | 04:09 PM
Matthew Eastes's Avatar
Default Need a little guidance for NA build.
I'm building a b16 head. So far I've bought crower stage 2 cams, Victor x intake, JG 65mm tb, 1320 toda header, aem camshaft sprockets. All this will be pushed by a ls block with high compression. I believe 11:5.1. I'm just wondering what else I could use. Opinions and criticism are welcome.
Old Mar 28, 2018 | 07:16 PM
SpiderX1016's Avatar
Default Re: Need a little guidance for NA build.
Valve springs, retainers and guides. Also valves themselves if you want.
Old Mar 29, 2018 | 01:23 AM
TunerThings's Avatar
Don't neglect the rest of the car!
Old Mar 29, 2018 | 02:49 AM
as far as?
Old Mar 29, 2018 | 04:55 AM
CandyRedRC46's Avatar
Originally Posted by Matthew Eastes
as far as?
Suspension, Brakes, maintenance etc....
Old Mar 29, 2018 | 05:12 AM
Are you using forged internals or just stock rods and ebay type r pistons?
If you are sticking with the factory rods and just adding reproduction type r pistons to them, I would at the very, least use ARP rod bolts and maybe even take it a step further, balance the rods/pistons and have the rods shot penned.
Adding to your list, oem head gasket, oem bearings (mic'd and color matched) and ARP head studs.
A crank girdle is probably out of the realm of this build, but a crank scrapper/windage tray would also help bring up reliability on a high revving LS build:
https://www.crank-scrapers.com/Honda..._B-SERIES.html
P.S. what are your plans for the rest of your exhaust (Everything behind the header)?
andersonkid531
17
Nov 7, 2011 07:43 AM
blade0314
36
Mar 12, 2011 08:25 PM
juba_x
Mar 22, 2008 11:11 PM
kyle-Lst
Jun 6, 2007 11:23 AM
Nicaraguense13
32
May 2, 2007 10:09 PM
