1998 Honda Accord slipping transmission
Old Mar 25, 2018 | 09:51 AM
Michelle Hanlon's Avatar
Default 1998 Honda Accord slipping transmission
Purchased a 1998 Honda Accord for $750 car is in great shape but did buy it knowing that the transmission was slipping I have plugged a one scanner in came back with P0730 At shift control for the code what I am wondering is when I looked up what the code ment it didn't give me much detail as to if it was a selelnoid problem or transmission needs to be replaced any ideas or help would be greatly appreciated
Old Mar 26, 2018 | 10:02 AM
somick's Avatar
Default Re: 1998 Honda Accord slipping transmission
I would try to drain/refill it few times.
Good luck,
Sam
Old Mar 26, 2018 | 11:35 AM
Good luck,
Sam
I have looked at the transmission fluid its clear and smells sweet so should I still drain and refill it
Old Mar 29, 2018 | 03:25 PM
Mason Edmison's Avatar
I would be hesitant to do a drain and fill at this point. The fresh cleaning properties of the ATF could be a nail in the coffin for the trans.
You may want to start looking/ thinking about a replacement. Re manufactured units go for about 1,000-1,500 dollars. JDM ( Japanese Domestic Market) transmission can be had for $350.
Old Mar 29, 2018 | 05:59 PM
MAD_MIKE's Avatar
MM Gruppe B
Bring the car to a quality transmission shop and have then do diagnostics. You will need to have the transmissions pressure ports verified for correct pressure and various known good solenoids on hand to verify it is not a fault with a leaking solenoid.
You can verify that the shift/pressure switchs are not clogged on the screen.
If there are any other codes other than 730, have those checked/fixed first.
lashune
Apr 20, 2017 12:22 AM
NoHondaexpert
Jan 2, 2014 09:43 AM
BlowmeOffValve
Dec 18, 2012 07:21 PM
mmadonich
Audio / Security / Video
Apr 18, 2009 11:54 PM
distortedcloud
Sep 26, 2006 06:19 PM
