95 acura Integra wont START HELP!!
I have a Acura Integra 1995 will it b8b1 got into a car accident border was just fine nothing damage to the motor bought the same shell same here put the motor in to the Shell started motor with no issues starting a second time with no issues and now the card no start no crank change the main relay change starter and change distributor what can be my issue and it's an automatic I feel like it's not on gear
check the neutral safety switch on the transmission and make sure its in park or netural when you are trying to start it when you got into a accident the shifter pro moved its position also check if your getting spark fuel and compression on the car anything is possible!!!
ecollinscona
Oct 23, 2014 12:39 AM
