Times the outter tie rod should turn when placing back.
Old Mar 23, 2018 | 11:43 AM
ArielAA's Avatar
Default Times the outter tie rod should turn when placing back.
How many times should I turn the outter tierod when placing it back in. I got the one of my car out but forgot the times it turned to get it out now when I drive it it shifts to the side can any one help please? It's a Honda Accord 94
Old Mar 23, 2018 | 12:25 PM
angrysmileyface's Avatar
Default Re: Times the outter tie rod should turn when placing back.
There is no set number of turns. If you lost what the setting is, you will have to get it re-aligned. This will vary from vehicle to vehicle.
Old Mar 23, 2018 | 02:40 PM
holmesnmanny's Avatar
the best thing to do is to check the other side, it should be similar, but obviously not going to be exact
and you always need an alignment when you mess with any tie rods
Old Mar 24, 2018 | 05:38 AM
GhostAccord's Avatar
Take it to a shop and have a proper aliment done.
shash911
May 3, 2016 08:48 PM
skhell
Suspension & Brakes
Apr 16, 2016 10:45 PM
Creator
Mar 22, 2011 01:35 PM
VTECIntegra9
Suspension & Brakes
Aug 14, 2008 02:02 PM
Tizzlers Ep3
Aug 3, 2006 06:02 AM
