Honda CR-V & Element 2WD & 4WD Element & CR-V
Always hot fuse
Old Mar 22, 2018 | 08:53 AM
dhealey's Avatar
Default Always hot fuse
I need to install a 12V socket that is always powered. Can anyone tell me a fuse number that is always hot? Thanks
Old Mar 22, 2018 | 06:36 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Always hot fuse
The positive battery terminal is usually hot. At least in my experience.
Old Mar 23, 2018 | 02:19 AM
ClabbeB's Avatar
As Smackin said.
Draw directly from battery and add a fuse for it
Old Mar 23, 2018 | 03:48 AM
dhealey's Avatar
Trying not to go through the firewall, thats why I wanted to tap a fuse.
Old Mar 23, 2018 | 07:55 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You’ve never included any vehicle information such as Year and Model.
Old Mar 23, 2018 | 09:02 AM
dhealey's Avatar
2014 Honda CR-V
Old Mar 23, 2018 | 03:28 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Tapping into a fuse in generally a bad idea. I’ve seen shoddy fuse jobs like what you are proposing and they’ve been the cause of problems.
But ill I’ll try to help.
Since you don’t want to go through the firewall, I’m assuming you want run a wire off a fuse in the under-dash fuse compartment. (Which I’m assuming exists in your model of car)
Also, since you’re performing electrical work, I’m assuming you have a handy dandy volt-o-meter.
In order to find an “always hot” fuse, get in the car, gain access to the under dash fuse box, and with the key off/removed and doors closed start probing fuses. In the unlikely event that you find an always hot fuse under there, please let us know.
Old Mar 23, 2018 | 03:40 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Based on the electrical circuit diagrams, the following under-dash fuses appear to be "Hot at all times":
B11, B12, B14, B16, B17, B25, B27, B41, B42
You can probably use something like an Add-A-Circuit low profile mini fuse tap.
You run the risk of excessive parasitic draw and a dead battery if the MICU does not go into sleep mode. Even if the multiplex control system is not affected, drawing additional power constantly may result in a dead battery, as there already will be some normal parasitic draw anyway; and you would be adding to that draw when the car is off.
Old Mar 23, 2018 | 04:49 PM
2x0's Avatar
2x0
10 Year Member
Curious why a constant hot is needed and not switched? I’ve used the add-a-circuit fuse adapters or tapped into wires from the ignition switch with good results.
Old Mar 23, 2018 | 04:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
My guess is he wants to use it for something like a dash cam for surveillance recording.
I also used add-a-circuit for ignition switched power without issues.
Old Mar 24, 2018 | 03:47 AM
dhealey's Avatar
I'm trying to run a aux brake so I can tow the car with my RV. I'm not against tapping into a "hot" wire under the dash or seat either.The brake unit has a minimal draw as it doesn't work unless needed.
Old Jun 5, 2024 | 06:31 PM
BobbyV's Avatar
I have a 2024 honda crv and I need to get to my battery via firewall. I was looking for access but couldn't find one. Am I looking at the wrong place. I need to hook up my positive wire from my. subwoofer, powered of course. Thanks
Crocky
Apr 19, 2017 11:03 AM
niceprelude
Sep 2, 2011 06:58 AM
Hanmin
May 16, 2008 02:17 AM
LUDE21
May 31, 2007 01:52 PM
george34
Audio / Security / Video
32
Aug 17, 2006 12:47 PM
